Heads or tails with output tones
Discussion in 'The Projects Forum' started by monkeyhead, Dec 3, 2007.
  1. monkeyhead
    Thread Starter Active Member
    Mar 5, 2007
    45
    Hi there,
    I'm trying to adapt a circuit so when it decides whether its heads or tails, a frequency will be generated at one desired frequency for heads and another different frequency for tails.
    However I am running into some problems. For example when the circuit is deciphering between heads and tails, the frequencies for the two tones are pulsing. They shouldn't be pulsing at this stage but should be when either heads or tails is chosen! I've tried everything, but am completely clueless!
    Any help would be greatly appreciated!
    Kind Regards,
    Matt
    Note circuit attached (Electronics workbench and screenshot of diagram)
