I know the title sounds silly.
Looking to connect:
Yamaha YDP-v240 piano stereo headphone output jack to the input of a
Crown D75a power amp.
I have no specs on the piano headphone output.
Crown D75a is as follows:
Input Impedance: Nominally 20 k ohms, balanced.
ominally 10 k ohms, unbalanced.
nput Sensitivity: Confi gurable for 26 dB gain
or 0.775 volt sensitivity.
So I have taken a stereo 1/4" TRS connector, red to tip, blue to ring and shield to sleeve. I would like to wire this to either 2 mono 1/4" plugs or 2 x XLR plugs.
Would a 4k7 resistor work on each 1/4" mono plug end?
or am I missing something?
thanks in advance
Andrew
Looking to connect:
thanks in advance
Andrew
