You're going to have to find datasheets for the original opamp, and look at the datasheets for other opamps you're considering to compare specifications and pinouts.
I'm not going to do it for you, since it appears you don't listen to me anyway.
Here is why the circuit eats 9V batteries:
1) The LED uses 16mA which is more than the entire circuit. Change its 1k resistor to 10k.
2) Each opamp has a 1k "bias" resistor at the output (that reduces the 0.05% crossover distortion) and uses 9mA each. You cannot hear distortion as low as 0.05% so the resistors simply waste battery power.
