Hi team,
i've been trying to find a solution for my problem for a few days now. My Beyerdynamic dt770 adapter tip has broken off inside my amps headphone socket. I need to remove it. Taking the amp apart give me no better access to the headphone socket itself. With the tip still inside the amp it has switched off the speakers circuit as well, so i am royally screwed.
I know if you have an adapter tip stuck inside an iphone you can use a q-tip, insert it and pull out a 3.5 mill broken adapter tip, but i am looking for the same sort of technique, but for a 6.3 mill adapter tip.
I'm reaching out guys. Any Heath Robinson ideas out there?
Thanks in advance.
Thanks in advance.
