headlight dimmer
Discussion in 'The Projects Forum' started by tojeena, May 5, 2009.
  1. tojeena
    Thread Starter Active Member
    May 2, 2009
    118
    Anybody pls send me some infos abt automatic headlight dimmer
  2. StayatHomeElectronics
    Sep 25, 2008
    864
    40
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    In the 1950's, dimers used a CdS cell and amplifier to sense light intensity. When it was "enough", the headlamps dimmed through a relay.
  4. tojeena
    May 2, 2009
    118
    Could u Please help me in providing some informations about light intensity controller in vehicles...Please....:confused:
  5. tojeena
    May 2, 2009
    118
    Could u Please help me in providing some informations about light intensity controller in vehicles..Could u pls also tell me whether this project is good or not..Please....:confused:
  6. DonQ
    May 6, 2009
    320
    11
    "Could u pls also tell me whether this project is good or not..Please"
    If that is the question, the answer to that question is... No. :eek:
    You should also realize that a headlight "dimmer" does not actually 'dim' the headlights. It switches to a second set of filaments in the headlights that are pointed at a lower angle. So the problems is not actually a "dimmer", it is a "switch".
    Now maybe you can ask a better question. :D
  7. studiot
    Nov 9, 2007
    5,005
    515
    Yes exactly, what is the question?
    Are you talking about Railway Engines, Automobilrs, mining helmets, models or what?
    What do you mean by 'automatic'
