HD44780 Power consumption
Discussion in 'General Electronics Chat' started by Tera-Scale, May 24, 2012.
  1. Tera-Scale
    Thread Starter Active Member
    Jan 1, 2011
    164
    5
    What is the power consumption of a HD44780 16x2 LCD powered normally at 5V ?
    Maybe average.. I know it will vary from when it is just displaying to when it receives data.
  2. t06afre
    May 11, 2009
    5,939
    1,222
    The best thing will be to check with the datasheet. For that 16x2 display.
  3. Tera-Scale
    Jan 1, 2011
    164
    5
    Yes, but I only managed to find the HD44780U datasheet which is the low voltage model. I am using the 5V model.
  4. t06afre
    May 11, 2009
    5,939
    1,222
    If you tell us which 16x2 display you are using. We may be able to help you out. Else it is hard to give any accurate answers. I did some research in my datasheet collection and found results around 3 mA. stated in the datasheet as max at 5 volt supply
    Tera-Scale likes this.
  5. MrChips
    Oct 2, 2009
    12,622
    3,451
    1 to 2mA is typical for a 16x2 display.
