HD44780 LCD interconnect and problems
Discussion in 'The Projects Forum' started by Geoffr67, Feb 12, 2012.
  1. Geoffr67
    Dec 5, 2011
    69
    Hello all,
    I have a pcb i designed that outputs text to a LCD to give status of certain things going on, on my PCB i decided to use a RJ45 connector to feed data to the lcd. On the LCD side i have made a daughterboard with this same connector along with a contrast adjustment pot. I am using a 3ft ethernet cable to connect the pcb to the lcd. the problem is, one of the lcds works fine, the other which uses the exact same LCD, and same parts, shows Blocks on the first line when initially powered up, it just does not work in the same manner as the first one, and has some noise on the screen. which is identical. The RJ45 connectors are not sheilded. anyone see any problems with doing it this way?
  2. MrChips
    Oct 2, 2009
    12,633
    3,453
    At the LCD, place a 0.1uF cap and 1uF to 10uF electrolytic cap between Vcc and GND.
  3. Geoffr67
    Dec 5, 2011
    69
    will try that thank you!
