i'm using dual channel opto hcpl2630 for my application.since its output is inverting mode, i am using a inverting stage(bjt) at its output.also it will do the reqd level shifting. the opto's HIGH Level Output Current is 100uA.and the vcc to opto pin 8 is 5V, the output im using to drive base of an npn transistro say 2n3019. to utilise the full 100uA, wat value of base resistor should i put?the bjt is tied to Vcc 15V, and wat abt the collectro resistr?
