Hello
My task was to make a h-bridge for 100W, 24V brushless DC motor.
The circuit should be able to draw 4A current from the supply. Also, the motor should be able to go in both forward and reverse directions with variable speed. The PWM that was given to the lower MOSFET was of around 15kHz.
The circuit was working fine at first but during switchover from forward to reverse the PMOS that was turned off (Vg=15V) was heating up. Afterwards the PMOS started to blow up and I can't seem to understand why.
Kindly help me out as soon as possible.
