Having trouble working on a broken gamecube need help!!!
Discussion in 'The Projects Forum' started by BlakesterGamer, Apr 20, 2016.
  1. BlakesterGamer
    Apr 20, 2016
    91
    so on the gamecube that is broken I tried to install a new lazer the lazer did not even work so I need help do you guys think that it is the disc drive I think it is because when ever I put a game in and go to the menu to play the game here is what it says reading disc... and then like 5 seconds later it tells me to put in a new disc I can not find a video on how to fix this am I the only one having this problem?
  2. gerty
    Aug 30, 2007
    1,154
    304
    Disc clean? Lens clean ? Have you tried a different disc and get same error message?
  3. BlakesterGamer
    Apr 20, 2016
    91
    I tried that
  4. gerty
    Aug 30, 2007
    1,154
    304
    Are you sure the disc is spinning? If all of this is good it looks like your laser or driver is bad..
  5. BlakesterGamer
    Apr 20, 2016
    91
    auctully I just remembered that it was not spinning
  6. gerty
    Aug 30, 2007
    1,154
    304
    I'm not at all familiar with your device, but most other drives run the motor and the busy led blinks for a few seconds whenever you close the drawer. If you take the top off some DVD drives a switch keeps the laser and possibly motor from turning on, look for one of those.
  7. BlakesterGamer
    Apr 20, 2016
    91
    ok I think ur talking about the 2 switches that gets switched when the drawer closes to let the gamecube know the lid is closed
  8. gerty
    Aug 30, 2007
    1,154
    304
    I've also seen switches that keep the laser off if you remove the top. That's to keep you from shooting your eye out, I guess....
  9. BlakesterGamer
    Apr 20, 2016
    91
    ok I just tested the gamecube the disc does spin only with the old lazer inside of it the new lazer does not even turn on or spin the disc
  10. gerty
    Aug 30, 2007
    1,154
    304
    Sounds like the new laser is not compatible with your needs. Can you meter your old laser to see if it is bad? Use meter on diode test , sould have a reading in one direction, but not the other (open)....
  11. BlakesterGamer
    Apr 20, 2016
    91
    well the gamecube is a console 15 years old and there are 2 models of the gamecube but I do not know if the 2 models use the same lazer or disc drive
  12. BlakesterGamer
    Apr 20, 2016
    91
    do you think I should just buy a new disc drive with the lazer for about $20
  13. Kermit2
    Feb 5, 2010
    3,838
    961
    If you're gonna spend money, get a used Wii system. All the old GameCube discs work in it. Seen them as low as $50.
  14. gerty
    Aug 30, 2007
    1,154
    304
    There you go !! Like I said before I don't know about game systems..
  15. BlakesterGamer
    Apr 20, 2016
    91
    no right now I am reparing my friends console for him he wants it repaired soon
  16. Dr.killjoy
    Apr 28, 2013
    1,204
    157
    With most disc drives the motor for the spin is broken and need to be replaced...
  17. BlakesterGamer
    Apr 20, 2016
    91
    no the disc spins with the old lazer with the new lazer it does not and the new lazer does not turn on either
