What size are you using for RH now?
Your TIP3055 is drawing lots of current through it's base. That's why I suggested using the IRF510 to begin with. The TIP3055 only has a gain of 70; that is for 1mA of base current, you get 70mA out. Your comparator is capable of SINKING up to 20mA. With RH of 220K and a 1K resistor from V+ to the output of the comparator and nothing else, the 1k resistor has about 11mA of current flowing through it, and the comparator is sinking most of that.
If you put a 1.5K resistor between the comparator output and the base of the TIP3055, that limits the current the base can draw. However, that also screws up the hysteresis, because it changes the voltage divider network drastically.
In order to fix the problem, you either need to use the driver circuit that I put up last time and fix the RH, or go back to the 2nd version of the original solution with the MOSFET, the 220K RH and the 1k resistor to the comparator output.
Note that if you INCREASE the value of RH, your hystersis will DECREASE.
If you change the value of the 1K resistor on the output of the LM339, it will drastically affect the rest of the RH feedback.
The resistor network on the input side of the LM339 also has a strong impact on hysterisis, along with the voltage level the comparator trips at. If you've used values that are different from what I have in the schematic I made up, you should tell me - otherwise, I won't be able to help you pinpoint the problem.
See the latest version attached, using a PNP transistor driver for your TIP3055 transistor's base. The MOSFET would still be a better solution, but sometimes you need to go with what you have, or what you know.
If you decide to use the PNP driver circuit, and you use something else than the specified transistor, let me know. I chose that particular transistor because it's commonly available, inexpensive, has high gain, and carries a fair bit of current.
