Having Trouble Using Logic Gates
Discussion in 'Digital Circuit Design' started by Aaron Laurenciano, Mar 10, 2016.
  1. Aaron Laurenciano
    Mar 10, 2016
    HOW can I make a logic "1" if two 4bit binary (0-9) inputs are the same and logic zero if not; with 8 switches connected to VCC. For example the 1st set of 4 switches are configured "1001" and the other is "0011" then it will have a logic "0"; and if the 1st set of switch are configured "1001" and the other set of switches are configured "1001" then it will have a logic "1".
    I attatched an image of my work (that obviously did not work) so might a little idea for you guys to help me. And if it is not possible with Logic Gates, what will?
  2. shteii01
    Feb 19, 2010
    3,501
    512
    Truth table, where?
  3. Aaron Laurenciano
    Mar 10, 2016
    I have no truth table, my friend and I are just changing the logic gates.
  4. crutschow
    Mar 14, 2008
    13,501
    3,375
    You can use a digital comparator such as the CD4063.
  5. RBR1317
    Nov 13, 2010
    265
    54
    The XNOR part is good; however, U5, U6, & U8 must be AND gates. Also, how did you ensure that when a switch is open there will be a logical zero signal applied to the gate inputs? Is this just a functional diagram, or is it an actual circuit schematic? Also, you should visually indicate which pairs of keys are intended to be compared.
  6. WBahn
    Mar 31, 2012
    18,087
    4,917
    In other words, you are hoping for a "happening", in which you make effectively random changes to your design hoping that, at some point, something will just "happen" to work.
    Would you like to discover that this is how your doctor diagnoses your health problems? Or how your mechanic fixes your car?
    If not, then you want to start learning how to DESIGN circuits, not just connect-and-pray.
    Think about the outputs of your XNOR gates. What does each one tell you if it is HI? What does each one tell you if it is LO?
    Now think about the output of one of the OR gates that follow a pair of XNOR gates. What does it tell you if it is HI? If it is LO? Are either one of these things particularly useful pieces of information given your objectives?
    What has to be true about that collection of those four outputs when the overall output of your circuit needs to be HI?
