Having trouble finding finding Diode
kunkles
Joined Apr 16, 2015
6
First post. woo
Im building a power distribution box to power multiple 12v devices it has an input for power from the wall and power from a VCLX battery. Im having trouble finding a diode that seems like it will work. It needs to support max current of 4-5 amps and a max voltage of 16v. Any help would be appreciated ive just been having trouble reading the spec sheets Ive been getting conflicting terminology through google.
thanks everyone
kunkles
Joined Apr 16, 2015
6
thank you. really dumb newb question but based on this i should be looking at the "Voltage - DC Reverse" for my max voltage? I guess ive been getting thrown off by "Voltage - Forward (Vf) (Max)"
34,286
Yes, reverse voltage is the maximum voltage it can block in the reverse direction, forward voltage is the voltage across it when conducting the stated amount of current (the forward voltage varies some with current).
kunkles
Joined Apr 16, 2015
6
hmmm ok. I installed the one i mentioned and i got some smoking once i started to put a good sized load on it. I have to check my current again when i get home, but i cant imagine its more that 3amps
kunkles
Joined Apr 16, 2015
6
right now its pulling 1.2A @ 150w there are a couple other things i need to plug into it and id like to have some headroom. I think i might possibly need 12amps @ 250w total
