Having trouble finding a relay
Discussion in 'Electronics Resources' started by stefon, Sep 9, 2011.
  1. stefon
    Sep 8, 2011
    Hello, I just found this website and it is wonderful, tons of information. My problem is that I have searched high and low (ie mouser, digikey) and cannot seem to locate this relay. I have included a picture of it. I am located in the US so I would need a local supplier. Can anyone suggest an alternative that would have the same values? Thank you for your time.
  2. elec_mech
    Nov 12, 2008
    1,513
    193
    Here is a link to the datasheet of your relay: http://www.datasheetdir.com/HFD27-005-S-L1+download
    I don't know if your relay is a single or double latching, but assuming the former, at a quick glance, I think this might work:
    http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=PB383-ND
    If not, Digikey carries several that should work, just go to Digikey, search for relays and use the datasheet of your relay as a guide to narrow your search. The one I found above was the first one I found - there were a few more.
