having problem with SPI/pic32mx and my inertial sensor unit (ADIS16448)
Discussion in 'Embedded Systems and Microcontrollers' started by ebtehal.younis, Apr 10, 2013.
  1. ebtehal.younis
    Apr 10, 2013
    hi all
    im using my pic32mx360f512l with explorer 16 to read my inertial sensor unit (ADIS16448) via SPI. im using pic32 compiler to write the code.
    i wrote a code and im receiving data, but i think im reading wrong data. i'm not sure where is the problem.
    if anyone can help me with thihs i'll be thankful.
    below is the code
    #ifdef __PIC32MX__
    #include <plib.h>
    #include <p32xxxx.h>
    #include <stdlib.h>
    #endif
    //********* Configuration Bit settings ************************
    // SYSCLK = 80 MHz (8MHz Crystal/ FPLLIDIV * FPLLMUL / FPLLODIV)
    #ifdef __PIC32MX__
    #pragma config POSCMOD=XT, FNOSC=PRIPLL
    #pragma config FPLLIDIV=DIV_2, FPLLMUL=MUL_20, FPLLODIV=DIV_1 // to have a system clock 80 MHz
    #pragma config FPBDIV=DIV_1, FWDTEN=OFF, CP=OFF, BWP=OFF
    #endif
    // RG9 as SS for SPI slave MCU
    #define SPI_SS_TRIS TRISGbits.TRISG9
    #define SPI_SS_PORT PORTGbits.RG9
    void SPI2Init(void)
    //config SPI1
    SPI2CONbits.ON = 0; // disable SPI port
    SPI2CONbits.SIDL = 0; // Continue module operation in Idle mode
    SPI2BUF = 0; // clear SPI buffer
    SPI2CONbits.DISSDO = 0; // SDOx pin is controlled by the module
    SPI2CONbits.MODE16 = 1; // set in 16-bit mode, clear in 8-bit mode
    SPI2CONbits.SMP = 0; // Input data sampled at middle of data output time
    SPI2CONbits.CKP = 1; // spi mode 3 ( based on the IMU )
    SPI2CONbits.CKE = 1; // spi mode 3 ( based on the IMU )
    SPI2CONbits.MSTEN = 1; // 1 = Master mode; 0 = Slave mode
    #define baud_rat 0x031; // fpb/(2*(49+1))
    SPI2BRG = baud_rat; // select clock speed so SCK is 800KHz
    SPI_SS_PORT = 1; //
    SPI_SS_TRIS = 0; // set SS as output
    SPI2CONbits.ON = 1; // enable SPI port, clear status
    unsigned short writeSPI2( unsigned short data )
    SPI2BUF = data; // write to buffer for TX
    while(!SPI2STATbits.SPIRBF); // wait for transfer to complete
    return SPI2BUF; // read the received value
    }//writeSPI2
    int main(void) {
    int j,k,i;
    SPI2Init();
    for (i=0; i<0xffff; i++); // a simple delay
    static short registers_data[12]; // to store sensors data
    //NOTE: the data should be stored in registers_data in the same order
    // as in pTxBuff, that is registers_data[0]holds pTxBuff[0] corresponding register data
    for(j = 0; j<12; j++);
    registers_data[j] = 0x0000;
    static short pTxBuff[12]; // register address
    //NOTE: below i wrote registers in that way so the MSB is the address and LSB is don't care
    pTxBuff[0] = 0x3C00; //status register
    pTxBuff[1] = 0x0A00; // X acc
    pTxBuff[2] = 0x0C00; // Y acc
    pTxBuff[3] = 0x0E00; // Z acc
    pTxBuff[4] = 0x0400; // X gyro,
    pTxBuff[5] = 0x0600; // Y gyro
    pTxBuff[6] = 0x0800; // Z gyro
    pTxBuff[7] = 0x1000; // X mag
    pTxBuff[8] = 0x1200; // Y mag
    pTxBuff[9] = 0x1400; // Z mag
    pTxBuff[10] = 0x1600; //baro
    pTxBuff[11] = 0x1800; //temp
    // main loop
    for (k=0; k<100; k++)
    SPI_SS_PORT = 0;
    registers_data[0] = writeSPI2(pTxBuff[0]); //1st byte to slave//dummy byte in buffer
    for(j=1; j<12; j++)
    registers_data[j-1] = writeSPI2(pTxBuff[j]); //j byte to slave//j byte in buffer
    registers_data[11] = writeSPI2(pTxBuff[0]);
    SPI_SS_PORT = 1;
    } // main loop
    while(1);
