Iam using Pic kit 2 burner
on my pic board there is a 8 Mhz crystal oscilator
iam using Mikro C for devloping code and i have selected 8Mhz frequency at the starting of new project
previously i was selecting 20Mhz for the code( i got to know that i was wrong)
i did select edit project from the project tool and in the oscillator section i have selected XT( coz someone had told me that if we use crystal of below 8 Mhz we have to select Xt and above that Hs is selected)
before that i was using default Hs for 8 Mhz and now when
i did the same i was instructed and when i burned it into the MCU using Pic Kit 2 what i see that it says device error after once it had
burned the hex file into it( and same with the another controller) and the device not found error on PIC kit 2
iam confused please somebody correct me
