Have you converted a Wall Wart ?
Discussion in 'General Electronics Chat' started by Seaker, Mar 21, 2013.
  1. Seaker
    Feb 3, 2013
    32
    I am looking for a cheap solution to provide 6 Volts AC with 500ma.
    I have been advised that I can take a Wall Wart apart and remove the
    rectifying parts and filters if any.
    A 6 Volt DC Wall Warts transformer will most likely supply somewhere in the 10 to 12 Volt AC range which is well above my requirements, so with this in mind I should be looking for maybe a 5Volt DC Wall Wart or less?
    I am hoping that someone might have had experience here.
    I realize that purchasing a step down transformer might be the better solution but the small size of the Wall Wart just seems a better fit.
  2. spinnaker
    Oct 29, 2009
    5,065
    1,176
  3. praondevou
    Jul 9, 2011
    2,936
    489
    I have transformed a 5V adapter to 6V. Luckily they were using the TL431 standard circuit in the feedback circuit, just needed to change one resistor.
    If you have an old 5V USB adapter lying around you can try this.
  4. PackratKing
    Jul 13, 2008
    850
    216
    Only mod I've ever made to a wart... I lucked across one from a mutilated paper shredder that was 24 volt and several amps... I would have to look..
    Anyway, I installed a switch in the case to select which the pin would be -- pos. or neg.
  5. Seaker
    Feb 3, 2013
    32
    I want to thank all that replied, it gives me much more to think about!
