Simple and clear
Answer title question no. "Simple and claer" opinion concur I not.Simple and clear
No, plastic does not have metal conductivity.Has plastic metal conductivity ?
Then the coating or filler would be conducting. The OP asked about plastic.Plastic can be coated or have fillers,etc... to make it both thermally and electrically conductive..
But most plastic is not electrically conductive.. It will conduct heat though (but not very well compared to metal)
Yes, in general. The thickness of the metal (usually aluminum) is less than 1 micron so static dissipation and capacitors are common uses for aluminized/metalized plastics.so the aluminium coated foil used for Ramen (instant noodles) is conductive?
Recently I use these foils for shipping since they are thick and good quality.
Id guess static could not build up on the plastic when it has aluminium coating?
Don't know about Ramen noodle foil, (mine come in a cellophane type plastic) but what do you thing is in a poly capacitor? And the individual layers of them are conductive, and will build a charge from static in the surrounding air.so the aluminium coated foil used for Ramen (instant noodles) is conductive?
The "chrome" plastic trim in a car interior is done this way. Worked in place that made car trim for a few years.The metal is deposited from vapor/arc in a vacuum.
Did they? I fail to see any reasonably stated question...Then the coating or filler would be conducting. The OP asked about plastic.
Sorry, I deal with ESL people all the time. My internal ESL to real English translation interprets the question as, "Does Plastic have the conductivity of Metal?"Did they? I fail to see any reasonably stated question...
It was "simply and clear" in their mind.. Not even close in mine..
"Has plastic metal conductivity? ".. wtf is that?
I just provided examples of how a part made of plastic could be conductive.. Via fillers/finishes..Sorry, I deal with ESL people all the time. My internal ESL to real English translation interprets the question as, "Does Plastic have the conductivity of Metal?"
by Jake Hertz
by Jake Hertz
by Aaron Carman
by Jake Hertz
