Has anyone been able to get this to work?
Discussion in 'General Electronics Chat' started by jordanwb, Jun 23, 2008.
  1. jordanwb
    Thread Starter Active Member
    Jun 22, 2008
    30
    I'm trying to build this circuit(the first one) for my traffic lights, but it's not working in real life. It works in KTechLab on my computer but not a real breadboard. What's happening is that both LEDs stay on and don't cycle.
    The only thing I did different was that I substituted 47K ohm resistors for the 100K. I tested all the individual components and they all work.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    It is a basic circuit, the kind they taught in my college. Both LEDs dark?
    The schematic is a bit unclear, in that the crossing wires should not be connected, but like I said, it is a text book drawing. My first thought is the caps may be flawed, or a transistor. How sure are you of your components?
    Try shorting each 100KΩ resistor with a 4.7KΩ-10KΩ resistor, this should cause the matching transistor to light up the LED, verifying the gain of the transistor and checking out the LED and resistor. Short the Collector Emitter of the transistor, this will verify the LED polarity is correct and the resistor is doing it's job.
  3. jordanwb
    Jun 22, 2008
    30
    I know that the crossing wires do not connect. I have tested the transistors, capacitors, and the resistors. They all work.
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    Sorry, missed that part, lift the base resistors, the LEDs should go out. It sounds like the gain of the transistors may be higher than the original design called for, if they go out try increasing them to 1MΩ. If you get a slow flash rate then bump the capicitors values down by the same ratio (0.1uF).
  5. jordanwb
    Jun 22, 2008
    30
    I took out the resistors connected to the base and the LED's did not go off. Could it be I mixed up Base and Collector? I always forget which is which.
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    It might still oscillate, check this circuit out for example.
    Just curious, do you have something against 555 timers? I came up with this circuit a while back for the same application.
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    That would do it.
    Do you have a basic layout sheet for this transistor?
  8. jordanwb
    Jun 22, 2008
    30
    No I don't have anything against 555 timers. I didn't look for a schematic using one because I don't have any 555 timers. The Source (Canadian version of Radio Shack) has them, I'll go pick one up tommorow. That seems even easier than the one I was using.
    Regarding your double post (shame), I did check to make sure they were NPN transistors. I'll change the Base and collector around and see what happens.
    [Edit] It works! I got base and collector backwards.
  9. Wendy
    Mar 24, 2008
    20,772
    2,540
    My suggestion, use what works for you, don't spend any more money than you have to. My tagline says it all.
  10. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    2N3904 transistors are mighty inexpensive compared to 555 timers. Of course, they're not giving capacitors away either nowadays... :rolleyes: Good job on getting it going :)
  11. jordanwb
    Jun 22, 2008
    30
    Well $3.99 for a 555 at The Source isn't a big deal for me. Thanks.
    Oh BTW I hooked up two red and two green LEDs in parallel on each side. The red LEDs turn on but the green don't. If I removed the Red LEDs, the green LEDs turn on. Do Red LEDs take more power than Green LEDs?
  12. Wendy
    Mar 24, 2008
    20,772
    2,540
    For that much you could order 10 from Jameco, look for the TI versions (lots of people manufacture 555's).
    The red leds drop a different voltage than green leds, and there is a difference between older generations and newer. Shouldn't make much difference to this circuit, but the 555 version cares even less. You can put a variable pot for the resistor to tweak to exactly the rate you like on the 555 circuit.
  13. jordanwb
    Jun 22, 2008
    30
    Ok thanks. The lights that are in the traffic lights I'm getting aren't LEDs anyways.
  14. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Oops - incandescents? :confused: Do you know their voltage and current rating?
  15. jordanwb
    Jun 22, 2008
    30
    No I don't have them yet. They're very small lights, so I don't think they'll take a lot of power.
    I just thought of something. What if the traffic lights I get have a yellow light? Then I don't think this circuit will work.
    I found this one though: http://home.cogeco.ca/~rpaisley4/20step.html
    The thing is I don't have the materials to make PCBs.
  16. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The thing is, that you will need to limit the current through your lights so that you don't instantly vaporize either the light filament itself or the transistor(s). You will probably want to run them at a slightly lower voltage than they were designed for in order to make them last a long time.
    No, it won't work as-is. It could be modified to add another RC timer and transistor driver, though. [eta] See the attached for an initial stab at a green-yellow-red-yellow-repeat sequencer. C1 and C3 should be reduced to get a shorter time for the yellow lights to be on.
    Funny, that's the exact same page I suggested to you in an earlier post on your other thread; next to last on this page:
    http://forum.allaboutcircuits.com/showthread.php?t=12515
    Rob sells the bare boards for $12/ea, and the complete kit for around $25.
    However, Rob's circuit is designed to drive LEDs. I suggest that before you experiment further, you obtain the specifications for the bulbs in the signals that you will be receiving.
    Or, do you have a link to the page where you ordered them from?
  17. jordanwb
    Jun 22, 2008
    30
    I have a 6 Volt DC transformer which I think will work nicely. Plus the transistors I bought today are rated for 30 volts.
    :D
    The lights in the traffic lights are very small, about 3/16" in diameter, although I am aware than by nature, Incandescent bulbs take more power than LEDs. I found a store on my side of town that specializes in electronics.
  18. Wendy
    Mar 24, 2008
    20,772
    2,540
    The funny part is, modern traffic lights use nothing but LEDs. Kind of an inversion.
  19. jordanwb
    Jun 22, 2008
    30
    Not where I live - oh wait you said modern. Lol. I went to the store today and they had a PCB with all the parts (you have to solder it together), needed to make of all things, a traffic light controller. I'm still not sure which to go for because I don't know if the semi-assembled one will handle non-LED bulbs. I one I/you found looks like it would.
  20. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You can always use a driver transistor or Darlington IC for that sort of thing.
    Actually now that I've had a chance to think more on this, I'd drawn up a circuit for a fellow months back that with some minor alterations should work quite well for something like this. I'll re-visit it and post something later.
