Has anybody ever seen a....
Discussion in 'Electronics Resources' started by BruceMellen, Aug 21, 2011.
  1. BruceMellen
    Jun 25, 2011
    11
    right angle version of the standard 4-pin PWM fan vertical male PCB header (special key w/friction lock) Molex 47053-1000 that mates with a Molex 47054-1000. I'd like to put it on the back edge of a PCB and could use either a SMT or through-hole version.
    I've had no luck searching so far...
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    www.digikey.com has many thousands of the 470531000 vertical through-hole pcb versions of the connector.
    hgmjr
  3. mcgyvr
    Oct 15, 2009
    4,791
    976
    Like molex 0022053041
    6K+ on hand at digikey
    Your searching skills are weak ;)
  4. BruceMellen
    Jun 25, 2011
    11
    That right angle connector does not appear to mate with the Molex 47054-1000 that is on the end of all the 4-pin fans I've ever known. The plug has a couple asymetrical rails acting as a key into the header I need.
  5. BMorse
    Sep 26, 2009
    2,675
    234
