Hartley oscillator simple project help
Discussion in 'The Projects Forum' started by leonheard, Jul 5, 2014.
  1. leonheard
    Jan 8, 2013
    48
    Hello!
    I need help for my next project... I want to build an hartley oscillator with a resonant frecuency of 9khz
    My power supply has 5.2 volts, my LC tank circuit is tuned to resonate at 9 khz ( no problem there I made the taped air coil about 14.15uH and 22uF capacitor) BUT what would be the values for
    R1,R2,R3,R4
    C1 = capacitor emisor
    C2 = capacitor output
    C3 = capacitor base
    Here is the link of that hartley oscillator….
    http://www.electronics-tutorials.ws/oscillator/osc6.gif
    I have basic knowledge in electronics
  2. Alec_t
    Sep 17, 2013
    5,973
    1,135
    Where is the tap in relation to the coil ends? Half way between, or ....? Is your 22uF cap non-polarised (since the voltage across it is alternating)?
    You could try R1=10k, R2=4k7, R3=2k2, R4=1k, C1=1u, C2=100nF, C3=100nF. However, I couldn't get a simulation of the circuit you posted to work with the coil tap grounded directly. It needed to be grounded via a >1uF cap instead.
  3. leonheard
    Jan 8, 2013
    48
    its in the middle.
    it is actually an electrolyte :/ i guess i will need to buy a non polarised one...
    Thanks! I didnt know that, how did you know that a >1uF cap needed to be used? :D
    Could you tell me the name of the simulation u use?
  4. Alec_t
    Sep 17, 2013
    5,973
    1,135
    Trial and error. That's the beauty of simulation :).
    I use LTspice (as do many on this site), a free download from Linear Technology.
    leonheard likes this.
  5. leonheard
    Jan 8, 2013
    48
    I thought you used maths, formulas etc lol xD
    wow! i have that software, i used only 1 time since i didnt know how to use it :p but now i will learn and use it more often.
    Thanks for the help!
  6. Alec_t
    Sep 17, 2013
    5,973
    1,135
    Recommended. Well worth the effort. It takes a while to get familiar with it, but there are good examples supplied, comprehensive Help, and a Yahoo LTspice user group for further help and free additional model libraries to download.
  7. RichardO
    May 4, 2013
    1,341
    429
    14 uH is an awfully small amount of inductance. I would increase the inductance of your coil and reduce the size of the cap.
    I would shoot for a maximum capacitor size of about 1 uF. This allows using a high quality polyester film capacitor. A 1 uH cap would need about 300 uH of inductance to resonate at 9 KHz.
