Harmonics?
Discussion in 'General Electronics Chat' started by wkyong, Apr 30, 2008.
  1. wkyong
    Thread Starter Active Member
    Apr 29, 2008
    33
    I have made a normal linear power supply using bridge rectifier, capacitor....Its i/p 240vac 50hz & o/p 220Vdc & load it up to 6A.
    I have seen the input current waveform at scope ,I think it is like harmonics current ?
    And found that the input isolation transformer become very hot.
    How to reduce or eliminate the input harmonics current produced by the non-linear diode ?
  2. mik3
    Feb 4, 2008
    4,846
    63
    maybe you put a big value capacitor for filtering and it draws much current from the supply due to the harmonics.
  3. The Electrician
    Oct 9, 2007
    2,301
    339
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    When 240VAC is rectified and filtered it produces 337VDC, not just 220VDC.
    So I think 117V x 6A= 702W is lost in the isolation transformer.
  5. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
