thanks for all the suggestions,
The gate resistor i replaced with a 1kΩ, measured Vgs: 20V, the mosfet is working comfortably (i suppose), & each string of LEDs, series with a resistor, no intension to modulate the current, but i still don't satisfy with the total current that passing thru the LEDs.
I recalled that at the beginning stage, when testing this circuit, before using heatsink to each LEDs, i fixed them all on an aluminium sheet (1mm thick, area 130 by 130mm) as dissipate heat, & the temperature rose till ~150°C! that might have effected the performance of the LEDs now.
i'm ordering another 4pcs of LEDs to test again, i'll keep you all inform by then.
thanks
thanks
