I made hard drive speakers by feeding an amplified music signal into the voice coil of an opened hard drive. It's producing music nicely, but I think I'm having problems with the music amplification.
The problem is that my hdd speakers don't behave the same way I see other hdd speakers working on Youtube. Their actuators oscillate back and forth in the middle of their motion range, whereas my actuator only pushes toward one side. Unless I turn the volume really low, this basically means that my actuator will just stay at that side (but still making music). If I apply a tension spring that pulls it toward the other side, then it will move as I'd like, but I don't want to resort to such a method. So how do I amplify it to get it to move like the ones I see on Youtube?
What I'm doing right now is feeding my headphone jack signal into an LM386n-1 op-amp, which outputs to the hdd. I gave the op-amp a V+ of 12V and a V- of ground. Am I right in guessing that my problem is that I need to give it a V- of -12V? If yes, then what is the easiest alternative solution (I don't have a -12V source)?
