Yes that is true, but the pcb can be quite hard to get for older models that are likely to fail about now.Not sure whether it's 100% true as I've not actually tried it myself but, I have heard of folk on extreme overclockers forums etc being able to recover data from, and even re-use a HDD with pcb failure by replacing the pcb with a pcb from the exact same model of drive.
You need to be positively sure that the failure is in the PCB (or in the HDD).Not sure whether it's 100% true as I've not actually tried it myself but, I have heard of folk on extreme overclockers forums etc being able to recover data from, and even re-use a HDD with pcb failure by replacing the pcb with a pcb from the exact same model of drive.
I have two hard drives and back them up to flash drive and DVD.Best plan is back up early, back up often.
by Jake Hertz
by Aaron Carman
by Jake Hertz
by Robert Keim
