Harbor Freight multimeter - comparison
Discussion in 'General Electronics Chat' started by someonesdad, Jan 15, 2011.
  1. someonesdad
    Thread Starter Senior Member
    Jul 7, 2009
    1,585
    141
    I did this comparison a few years back, but forgot to put a date on it. Regardless, it's a comparison of one of the cheap (under $5) Harbor Freight meters to an HP digital voltmeter. Except for resistances under a few tens of ohms, it did quite well. I don't have my HP meter calibrated, but it agrees with my Fluke differential meter within 10 ppm (and a precision HP power supply); both are awesome meters.
    I believe SgtWookie said he did a similar comparison to a Fluke calibrator and got similar results.
    The bottom line is that you simply don't have much of an excuse not to have a digital multimeter if you have access to a Harbor Freight store.
    Note that CenTech is a Harbor Freight brand name.
  2. tom66
    May 9, 2009
    2,613
    214
    Those cheap meters are nice.
    And they're fairly rugged - I've measured 230V mains on the ohms range with no explosion, and it still worked okay after it.
    Only one problem. I dropped one off my bench and it didn't work any more. So they aren't as rugged physically, but you're not going to get much for £3/$5.
  3. marshallf3
    Jul 26, 2010
    2,358
    201
    I've pulled test leads out of the probe tips. I just keep a pile of them around as they often go on sale for $2 - $3
