hand switch
Discussion in 'General Electronics Chat' started by jkliegman, Nov 13, 2005.
  1. jkliegman
    Nov 13, 2005
    i am working on an ac circuit in which a hand switch opens and closes the neutral line, while the hot line runs through the circuit unabated.
    is this ok? or correct?
    jon
  2. richbrune
    Oct 28, 2005
    106
    Nope--that's not legal in the U.S., nor is it safe.
    You might check, however, that the line is actually a neutral--- in some rare cases where Rhomex type jacketed cable was used, you might find a white wire used as a switch leg. That would only be found in a residence, though, and the installing electrician is supposed to mark the ends of the white wire with tape to signify when it is NOT a neutral. Better fix that one.
  3. jkliegman
    Nov 13, 2005
    Thanks, I'm on it!
