Hand scanner (portable)
Discussion in 'General Electronics Chat' started by krebma, Oct 25, 2013.
  1. krebma
    Oct 25, 2013
    5
    Hi to every one i wasn't sure if this was the place to ask... But anyways i would like to get some opinion from the experts i have a hand scanner and u might know better that it works with infrared ( i think thats how it written) like the same system as old style ball mouses... I want to cancel that out and replace it so it works constantly... I hope i could explain it and waiting for your advises.
    Thanking from before hand.
  2. wayneh
    Sep 9, 2010
    12,365
    3,220
    I can't imagine what you're talking about. Maybe a photo would help.
    Most IR mouses shine very brightly until they "see" the reflected signal. Then they dial it down to save power. If you blind it so it can't see the reflected signal, it will continue to shine brightly. I have no idea if this helps.
  3. krebma
    Oct 25, 2013
    5
    Ill try to get same pics.
    Thanks for the quick reply
  4. krebma
    Oct 25, 2013
    5
  5. wayneh
    Sep 9, 2010
    12,365
    3,220
    I think I understand now. You want "continuous" scanning, without needing the wheels to turn? Maybe if you explain why you want that, someone will have another idea.
    I really can't help but hopefully someone here that can, will come along soon.
    I guess the device is meant to use the turning of the wheel as a measure of distance, so that a scanned page is assembled by a series of horizontal strips. My guess is that proper control of the software driver might allow you to do exactly what you want without changing the hardware. But that is a useless strategy unless there's an open source driver for your scanner, and unless you know what to do with it.
  6. krebma
    Oct 25, 2013
    5
    Thanks alot wayneh
    The scanner actually works with a button u press starts and as u said the wheel turns but the wheels actually makes the scanning light work not to measure distance because i can scan continously until i press scan off button again.
    Reason is when i scan my books the wheel sometimes hit a bump and wont turn and the scan is not the best...
    I know the explaning is not the best... Sorry...
  7. Ramussons
    May 3, 2013
    561
    92
    Would'nt it be simpler to take photos with a digital camera? - just a thought.
    Ramesh
  8. MrChips
    Oct 2, 2009
    12,622
    3,451
    The wheel is an integral part of the design.
    Yes, the wheel measures distance in the sense that it tells the scanner when to scan the next row of dots.
  9. krebma
    Oct 25, 2013
    5
    Ramesh, i know what u mean but at the moment can not afford a digital camera.. Thanks for the tip.
    Thanks to you MrChips too.. I thought i could replace something else with the ir led and ir reciever..
