hamming sound noise
Discussion in 'The Projects Forum' started by Benengineer, Feb 6, 2016.
  1. Benengineer
    Feb 6, 2016
    101
    The customer returned the products which has hamming sound with with its circuits. But after we took the Zener Diode and the problem is solved. I am sure which part generates this sounds. Please help me with this question. When I tested TP12 before Zener diode Z1 removed, the output at TP12 was about 5.6V since Z1(SMAZ5V6) stabilizes at 5.6V. But after Z1 was removed, the output at TP12 was 5.9V, then hamming sound was gone. Can you tell me what happends to this circuit? I colored Zener diode Z1 with Red. The input consumer current is about 32.67mA before the Zener diode Z1 was removed. After it was removed, the input consumer current decreased to 27.45mA. So, the hamming sound is gone
    Thank you for your help.
  2. SLK001
    Nov 29, 2011
    852
    243
    The hamming noise, was it like an "oink, oink", or more like a squeal?
    shortbus, boatsman and wayneh like this.
  3. Benengineer
    Feb 6, 2016
    101
    I am not sure the noise is like "oink, oink" or squeal? Can you explain both of them to me? But after I removed the Zener diode, the sound was gone. I want to know why.
  4. wayneh
    Sep 9, 2010
    12,403
    3,253
    It was a joke. You mean "humming". Ham is a cured meat made from pigs, so a "hamming" sound is what a pig makes.
  5. Benengineer
    Feb 6, 2016
    101
    Sorry, I mean the sound more like data transferring on the bus between severs. There is noise sound there.
  6. Benengineer
    Feb 6, 2016
    101
    Please let me know what reason causes this sound. Why the sound was gone after it was removed from the circuit?
  7. Dodgydave
    Jun 22, 2012
    5,167
    777
    It is working ok or not, if Yes then don't bother about it, if No then replace the zener.
  8. Benengineer
    Feb 6, 2016
    101
    It is working after the Zener diode was removed. But I want to know what caused this noise sounds before it was removed. Is it an avalanch noise sound?
  9. ericgibbs
    Jan 29, 2010
    2,604
    396
  10. Benengineer
    Feb 6, 2016
    101
    Thank you for your explanation. It makes sense to me now. It is very good forum. I like it.
