Hamming encoder/decoder circuit
Discussion in 'Homework Help' started by jegues, Oct 3, 2010.
  1. jegues
    Sep 13, 2010
    735
    43
    Hello everyone,
    We've been given the task to design a hamming encoder circuit as well as a decoder circuit.
    The encoder accepts a 4-bit input mesage and outputs a 7-bit Hamming code.
    The decoder accepts a 7-bit input and generates a corrected 4-bit output.
    The only introduction we've been given so far is nothing but a very short paper on what Parity, Hamming Distance, Hamming Code is.
    So as you might have guessed, I'm pretty confused as to how I'm suppose to build a Hamming encoder/decoder circuit.
    I think they are expecting us to do it using regular logic gates as well. Is this possible?
    Can someone give me a nudge in the right direction so I can atleast get some rough designs started?
    Thanks again!
    Also, they have a few side questions as well that I'm confused about. One of them is,
    How many codewords can be generated using 7 bits? If we use a Hamming code, how many valid codewords do we have?
    My guess would be for something with 7 bits, we would have 2^(7) possible code words. I'm not really sure how this would change if we use Hamming code.
    Again, if I could get the ball rolling on some of this stuff that'd be great!
  2. jegues
    Sep 13, 2010
    735
    43
    Bump, still looking for some ideas on this one.
  3. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
