Can you tell me what's the original value of the received message 0x65c assuming there are no more than 1 mistakes? If possible please tell me how did you solve it The value is in hexadecimal
Only if you define the exact coding scheme used. There are MANY Hamming codes and many more transmission protocol schemes employing them.Can you tell me what's the original value of the received message 0x65c assuming there are no more than 1 mistakes? If possible please tell me how did you solve it The value is in hexadecimal
What, impatient after only 45 minutes?All help is much appreciated
Thread starter | Similar threads | Forum | Replies | Date |
D | decode hamming code with added noise | Analog & Mixed-Signal Design | 8 | |
N | Need help with Hamming code | General Science, Physics & Math | 2 | |
R | Hamming code (7,4) | Homework Help | 1 | |
B | xilinx help: Hamming Code Decoder | FPGAs (Field Programmable Gate Array) | 0 | |
J | need help about 8-bit hamming code | General Electronics Chat | 1 |
by Duane Benson
by Duane Benson
by Aaron Carman
