Hammer energizer
Discussion in 'General Electronics Chat' started by tafuma, Mar 13, 2008.
  1. tafuma
    Mar 13, 2008
    I am working on Hammer EZ680 electric fence energizer. Its coming up with fence alarm LED on. Both mains and battery leds are on. The other 7 leds for zones not coming on. Measured all components working fine. Does any one have some ideas on how i can diagnose the fault.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I would turn the alarm off, and short each lead going to the 7 fence zones to ground for several seconds in case there is a residual charge. Then I would disconnect the leads going out to the zones one at a time, and check their impedance. If you show less than infinite impedance, there is a problem.
    You'll probably need a megger (insulation tester) to check the impedance.
