halloween oscar the grouch costume
Discussion in 'The Projects Forum' started by cl10Greg, Oct 11, 2010.
  1. cl10Greg
    Thread Starter Active Member
    Jan 28, 2010
    49
    Hi everyone.
    So for halloween I am going be oscar the grouch and I want to have some fun electronics to go with. I have a trash can that has 5 inches of clearence per side and will use a backpack to help carry the weight. I want to have two lighting effects. 1 is a rgb controller powered by and arduino and transistors. The other is some 12v cold cathods I have. My question for now is how far away should the leds be from the can to have a cool lighting effect. I will post more when I get home from work but this is my firsr question for now. Thanks
  2. R!f@@
    Apr 2, 2009
    8,793
    771
    It depends on the LEDs light dispersion angle
  3. cl10Greg
    Jan 28, 2010
    49
    Ok sorry I am at home now and can elaborate more on things. The LEDS are 8000 mcd and have 30 degree viewing angle. I was originally going to just mount them on the rim pointing up but then I realized how dumb that would be because they would just point to the ceiling and wouldnt light the can up at all. Thats why I am wondering about optimal lighting distance.
  4. R!f@@
    Apr 2, 2009
    8,793
    771
    What do U mean by lighting the can
  5. wayneh
    Sep 9, 2010
    12,405
    3,256
    LEDs are much better as "be-seen" lights than for providing indirect illumination. I'm not saying you can't do what you want, just that an LED pointed at the viewer can look incredibly bright whereas a single LED doesn't make for much of a flashlight.
