Hall sensor as limit switch
Discussion in 'The Projects Forum' started by k9electroman, Nov 2, 2011.
  1. k9electroman
    Nov 2, 2011
    I am driving a axis with a stepper motor and want an accurate home switch. The problem is my work environment is 77 Kelvin. The hall sensor i am using the FH-301-040 by FW BELL. This is because it works in extreme cold and cheap ones don’t. The motor controller needs digital input (>2.2volts) to sense "home" but the hall sensor only outputs 30ma. :confused:
    What kind of control circuit can I use?
    Here are the specifications of the hall sensor.
    fwbell.com/file/FH-300_500.pdf
  2. praondevou
    Jul 9, 2011
    2,936
    489
    That's one of the worst datasheets I've seen. Even on their website I didn't see much more information about it.
    The only thing that is quite explicit is that the output is a voltage output.
    "With field direction (+B) as shown <obs. shown where?> and Ic entering the Ic (+) terminal, the positive Hall voltage will appear at the VH(+) terminal"
    Are you sure you mean 77 KELVIN ??? This sensor works down to -55 Celsius, that's 218K so it would not work anyway.
  3. k9electroman
    Nov 2, 2011
    I agree the spec sheet is lacking. Yes I am sure about the temperature "77.36K". That is liquid nitrogen’s boiling temp. Most component specifications only go to -55F (224.8K) so I must do my own testing down to 4K. Some things work, most don't. I hear this hall sensor works cold, down to 30K. I just can’t figure out how to drive it accurately.
  4. praondevou
    Jul 9, 2011
    2,936
    489
    Me neither. It's not described in the datasheet. You could try to pass the nominal current through the Ic terminals and see what happens to the output voltage when applying a magnetic field.
    I would contact the manufacturer directly. Also, according to the datasheet it works only down to -55 Celsius.
  5. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  6. John P
    Oct 14, 2008
    1,638
    225
    Could you replace the magnetic switch with an optical one, with the transmitted and received light beams traveling down optical fibers? That way the electronics could stay in a warm environment. I doubt if there are any components specified for temperatures below 100K.
    Edited to say: If the electrical properties continue to work at very cold temperatures, could you use an inductive or capacitive sensor? I can imagine ways to do either of those.
  7. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    In our company we are using electronics on very low temperatues to reduce the noise:
    So it is possible to use special electronics at very low temperatures.
    Bertus
