Hall effect
Discussion in 'General Electronics Chat' started by pilotnmech, Jan 26, 2006.
  1. pilotnmech
    Feb 26, 2005
    27
    How does it work? How does a cam sensor work with it? Thanks.
  2. n9352527
    Oct 14, 2005
    1,198
    You can start with this Hall Effect sensor page on Wiki. You could always search for more materials if you feel you need more information.
  3. kubeek
    Sep 20, 2005
    4,689
    806
    Oh, now I understand.
    You don´t mean Hall efect as a type of echo, but Hall sensor...
  4. nanobyte
    May 26, 2004
    118
    An Hall Effect sensor simply generates a voltage in response to a magnetic field. There are three pins on the device. The two outside pins go to +5V and ground respectively while the middle pin is the output. An application for it would be to use it in a circuit to control the speed of a DC motor with a magnet.
  5. pilotnmech
    Feb 26, 2005
    27
    I really want more info. in lesson form about how, and why it works, applications, etc. Just like the lessons here. Is there a really good web page?
  6. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
