Well guys, I agree that most of my issues are possibly because of the supply voltage. I started out using a 9v battery, but am currently using a 9v "wall-wart" which obviously cannot handle the current required by the 2 circuit boards. As I mentioned earlier, I am in the process of building a regulated 9v, 1-amp power supply which should give me the proper Vcc. Incidentally, I contacted the manufacturer of the Wind Speed module and he supplied me with the exact sensor. Here it is: http://uk.farnell.com/allegro-micro...fect-sensor-sip-3-1301/dp/1198085?ost=1198085 The "HAL575" reference that I gave you earlier is what is stamped on the sensor, which now may be a misnomer and I may have been leading you guys down the wrong path... my humble apologies if this is the case. Please see if this makes a difference in how we are trying use it's signal. BTW, if you are concerned about the 5v operating voltage for the sensor, the Wind Speed module has a 5v regulator and 2 large capacitors on-board which drives the display, microprocessor and sensor, but module was designed around a 9v supply, hence my desire to design our timer around a 9v supply as well. As far as the magnets are concerned, I am using 1/2" x 1/8" round neodymium magnets (10800 g) on a 3-spoke wheel that rotates with a very slight amount of wind. The sensor is mounted approx. 3/16" from the magnets, which should be close enough to stimulate the sensor, don't you think? I feel confident that I have all 3 magnets oriented the same direction, but they may be backwards... will try to verify the South pole is facing the sensor. I should have the power supply completed within a few days (just waiting for a few components), so please bear with me. I really appreciate your input and expertise with this project. Thank you SO much! Please "stay tuned"
