meassuring direct onto the sensor i get 0.14 volts without a magnet and it drops to 0.1 volts with a magnet
Something is clearly amiss. The output of the HE sensor should swing between around 12 volts (without a magnet) and near 0 volts (with a magnet).meassuring direct onto the sensor i get 0.14 volts without a magnet and it drops to 0.1 volts with a magnet
I found information that leads me to strongly suspect that the output transistor you are using is an NPN darlington. That would explain the 2.26 volt figure that you are getting for the voltage at the collector of the BC548.i have removed both diodes from the circuit and i have replaced the 100ohms resistor from the sensor the base to a 10K.
i am getting 0.11 volts on base and it drops to 0.01 when stopped over a magnet
the collector is 2.26 volts and does not move when a magnet is placed over the sensor and is saturating the power transistor
Which base are you referring to?i have very quickly connected up my last HE switch .
i get from the base 2.60 volts with out the magnet and 0.1volts on a magnet
Let me make sure I understand what you are telling me.sorry . the base direct on the sensor. i get 0.13 volts on the base of the transistor
