Hall effect sensor
Discussion in 'The Projects Forum' started by cpleng7, Jul 19, 2010.
  1. cpleng7
    Thread Starter Active Member
    Dec 18, 2008
    120
    Is that the hall effect sensor can measure the output power of the induction motor?
  2. BMorse
    Sep 26, 2009
    2,675
    234
    There are all sorts of different types of Hall effect sensors, there are Unipolar, Bipolar, Latching, and even some with analog output....
    I have seen the analog ones used for detecting current draw, but not output power...
    B. Morse
  3. cpleng7
    Dec 18, 2008
    120
    Is that any sensor is using for the output power measurement
  4. BMorse
    Sep 26, 2009
    2,675
    234
    to measure output power you would need some kind of dynamo setup...
    B. Morse
  5. windoze killa
    Feb 23, 2006
    605
    24
    I am not sure what you mean by "power output of an induction motor". Do you mean how much power it uses when it is operating? Do you want to know how much power it uses when operating normally or when it is in a stalled state? Are you trying to find out the amount of electrical power or mechanical power? A single line question is very hard to answer.
    Having said that you can use a hall effect device to measure the current drawn by the motor and then use some more circuitry to indicate what this current is. You could even convert it into a power indication.
  6. cpleng7
    Dec 18, 2008
    120
    is that have a lot of different between then electric power and mechanic power? i think i have to find electric power of the induction motor output.
  7. windoze killa
    Feb 23, 2006
    605
    24
    We need more information. Type of motor. A schematic of how it is wired. What you are actually trying to achieve.
    cpleng7 likes this.
