hall effect sensor
Discussion in 'Embedded Systems and Microcontrollers' started by kamalsolimen, Oct 20, 2014.
  1. kamalsolimen
    Oct 3, 2014
    18
  2. Kermit2
    Feb 5, 2010
    3,847
    963
    looks like you need a resistor between your supply line and your sensor output. the voltage/signal there would become an INPUT to your micro. rbo would then become an input to your circuit driving the LED
  3. kamalsolimen
    Oct 3, 2014
    18
    i try to add resistor in output senssor puls pin 10 ohm
  4. Kermit2
    Feb 5, 2010
    3,847
    963
    10 is too small. should be about 1k or larger.
  5. Kermit2
    Feb 5, 2010
    3,847
    963
    see photo
  6. kamalsolimen
    Oct 3, 2014
    18
    ok thanks i try , its like switch or restart pic16f877a
  7. Kermit2
    Feb 5, 2010
    3,847
    963
    yes, sensor will be like a switch. using pic to output to led, the sensor will become an input to the pic.
  8. kamalsolimen
    Oct 3, 2014
    18
    thanks its working thanks thanks thanks alot
  9. Kermit2
    Feb 5, 2010
    3,847
    963
    I'm pleased it worked. Thank you for posting and letting us know this. Many people do not follow-up and tell us how their problems are resolved.
    kamalsolimen likes this.
