Hall current sensor
Discussion in 'General Electronics Chat' started by Dritech, Nov 30, 2013.
  1. Dritech
    Sep 21, 2011
    756
    5
    Hi all,
    I am going to use the ACS755 current sensor, but am not sure how to connect it. If I connect it as shown in the diagram attached, will it work?? (Note: I did the diagram so I'm not sure if it is connected correctly or not)
    Thanks in advance.
  2. R!f@@
    Apr 2, 2009
    8,787
    771
    The power track should be cut so tht current passes through the sensor.
    The two huge tabs are in/out or the current shunt
    See the pdf
    Dritech likes this.
  3. Dritech
    Sep 21, 2011
    756
    5
    Thanks for the reply. Is this IC obsolete ?
    Should I use the ACS712 instead?
  4. mcgyvr
    Oct 15, 2009
    4,787
    973
    yes its been obsoleted since 2009.. refer to allegros site for an active one that fits your needs..
  5. praondevou
    Jul 9, 2011
    2,936
    489
    There are several other similar chips. I use the ACS758 all the time. Great little ICs.
  6. Dritech
    Sep 21, 2011
    756
    5
    Thanks for the replies. Is there an IC that comes in a DIP package to measure currents form 0 to approx. 20A ?
