The problem is a half-wave rectifier with a 1k-ohm load operates from 120V rms 60Hz through 10 to 1 step down transformer. The diode has constant voltage drop of .7 V for any current.
Find peak voltage of rectified output.
The AC voltage is stepped down to 120/10 = 12V rms
The peak rectified output voltage should be 12 - .7 = 11.3V. The answer given is 16.27V. Can someone please point me in the right direction?
Thanks.
Thanks.
