half-wave rectifier in pspice
Discussion in 'Homework Help' started by mr.harm, Nov 2, 2013.
  1. mr.harm
    Nov 24, 2008
    29
    the output current waveform is inverted, any idea why it comes out like that?
    circuit in pspice
    output current
    thanks,,
  2. LvW
    Jun 13, 2013
    674
    100
    Yes - the current through a device like L is defined for a certain direction only.
    Thus, probe the upper node of the inductor and there will be no inversion.
  3. mr.harm
    Nov 24, 2008
    29
    many thanks LvW,, it has worked perfectly,,
  4. LvW
    Jun 13, 2013
    674
    100
    The same applies also to resistance R and capacitor C.
    The direction of a current is defined in the direction from x to y.
    However, normally you cannot identify these nodes by a simple visual inspection only.
