Half wave rectifier diodes
Discussion in 'General Electronics Chat' started by sealdogfish, Nov 15, 2011.
  1. sealdogfish
    Nov 15, 2011
    15
    Hi all!
    I'm working on a project, I have a pressure sensor with a -50mv to +50mv output, I have 2 AD8666 op amps set up, one inverting one non inverting, what sort of diodes should I use on the outputs for half wave rectification?
    I've looked all over google and the forums and all they say is diode..
    Gain is 40 btw, I want the output from the non inverting to be 0V to 2V when the pressure sensor is 0 to 50mv and the output from the inverting to be 0 to 2V when sensor is 0 to -50mv
    (Both op amps are set up correctly and working, it's just the half wave rectifiers..)
    Thanks!
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Can you post a schematic of your setup. So we can be 100% sure about your setup
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You should look up "precision rectifier".
    If you don't use a precision rectifier, the forward voltage of the diode will introduce an offset. Precision rectifiers compensate for that voltage drop.
    See this page:
    http://sound.westhost.com/appnotes/an001.htm
    Look at figure 3.
    Note that you will need to use a dual-rail supply (both negative and positive supplies).
  4. sealdogfish
    Nov 15, 2011
    15
    Here is the schematic:
    That second ADC1 should be ADC2 btw,
    So what diodes should I use and where to place them? I have read that website but again it does not mention the particular diodes to use
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You need to have a negative supply, or else the negative portion of the waveform will be truncated (clipped off) at 0v.
    After that, you can use 1N914 or 1N4148 diodes.
    [eta]
    If you really don't want to have a negative supply, you might use a pull-up resistor on your input signal to get the entire signal above 0v; but you will wind up with some attenuation.
  6. sealdogfish
    Nov 15, 2011
    15
    OK, so all the ground connections should be -3.3V?
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    No, just the negative supply for the opamp(s). Everything else stays connected to ground.
  8. sealdogfish
    Nov 15, 2011
    15
    Thanks, I'll do that now and see how it works
  9. crutschow
    Mar 14, 2008
    13,472
    3,359
    Corrupted post
  10. crutschow
    Mar 14, 2008
    13,472
    3,359
    Here's a full-wave precision rectifier that requires no diodes and no negative voltage supply (it actually won't work properly with a negative supply). It does require a rail-to-rail type op amp.
  11. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Carl, I looked at that exact article a few years ago, but the output left a good bit to be desired. There was quite a bit of distortion when it got near ground.
  12. crutschow
    Mar 14, 2008
    13,472
    3,359
    Was that a frequency dependent type of distortion?
  13. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I don't remember; it's been a good while. I just remember that it didn't behave well around the ground rail. I'll have to do some digging to see if I can find it.
  14. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, I found my simulation of it, and I'm wondering what I saw over a year ago that caused me to not like it?
    Looks pretty good from what I can see. I really didn't change anything.
    V(out) is being overlaid by V(in) on the positive swings; it's there.
    Perhaps I'm getting that one confused with another similar circuit I was simulating at the time. I don't know ... it's late and I'm mighty tired.
