Half-Wave Rectifier Average Diode Current
Discussion in 'Homework Help' started by Petrucciowns, Jul 1, 2009.
  1. Petrucciowns
    Thread Starter Active Member
    Jun 14, 2009
    62
  2. vvkannan
    Aug 9, 2008
    138
    11
    Hi Petrucciowns,
    The average load voltage divided by the load resistance will give you the average load current which is the average diode current.
  3. Petrucciowns
    Jun 14, 2009
    62
    Thanks for the reply,
    Hm, I know that is how to find the peak diode current, but the average diode current is different. How is the average diode current found? I tried to see if it was the same value in RMS but that is not correct. So I'm stumped.
  4. Jony130
    Feb 17, 2009
    3,993
    1,116
    To find a average voltage, you have to finding the area under the output curve over a full cycle (2∏)
    So you need to calculate the definite integral from 0 to ∏, to find area under the curve.
    And then:
    Vavg=area/2∏=1/2∏*∫Vpsinθ dθ =Vp/∏
  5. Petrucciowns
    Jun 14, 2009
    62
    Awesome that was exactly what I was looking for.:)
