Half wave rectification question
Discussion in 'The Projects Forum' started by Hk606, Mar 9, 2015.
  1. Hk606
    Oct 19, 2014
    19
    My project requires 12 volts DC 29mA. The input voltage to the project is 24 volts Ac 2.0 amps this is a must.
    As my load is so small, For simplicity purposes I'd like to use a simple half wave but I don't know what size filter cap to
    use across on the output. to control any ripple. I would be grateful for any help. Thanks
  2. Dodgydave
    Jun 22, 2012
    5,172
    778
    Any size from 470 to 1000uF , the voltage after rectifying will be approx 16V open load.
  3. alfacliff
    Dec 13, 2013
    2,449
    428
    he input current at 2 amps is decieving, just because a power supply or wall wart is rated 12 volts at 2 amps does not mean that 2 amps is necessary, the current depends on the load;. the current rating just tells you tghe maxumum it will put out. your 24 volt ac transformer will be putting out 29 ma RMS, the load current.
    #12 likes this.
  4. #12
    Nov 30, 2010
    16,705
    7,358
    (Square root of 2) C Er(peak to peak) F = I
    Roderick Young likes this.
  5. wayneh
    Sep 9, 2010
    12,406
    3,256
    You need to define what you mean by "control". For 100% ripple, do nothing. For 0% ripple, give up now. For something in between, there are options.
    ebeowulf17 and #12 like this.
  6. Hk606
    Oct 19, 2014
    19
    Yea I just wanted to give all the info on the project. Thanks for getting back
  7. Hk606
    Oct 19, 2014
    19
    Thanks for the help. If the 24 volts weren't needed for other relay control it would have been easier, not that what I'm doing is complicated for sure!
  8. RamaD
    Dec 4, 2009
    254
    33
    What is the tolerance of your project requirement voltage of 12V, 29mA? The half wave rectified voltage will have a peak of around 33V.
  9. MikeML
    Oct 2, 2009
    5,451
    1,066
    Here is how I would do it.
    Note the voltages at the three named nodes. Note the little bit of ripple left in the load current...
  10. wayneh
    Sep 9, 2010
    12,406
    3,256
    R1 limits the current into the cap?
  11. MikeML
    Oct 2, 2009
    5,451
    1,066
    Yes, and greatly reduces the wasted power...
    aungkyaw and wayneh like this.
  12. MikeML
    Oct 2, 2009
    5,451
    1,066
    I screwed up the load current. Here is revised circuit that will make 29mA in the load.
  13. #12
    Nov 30, 2010
    16,705
    7,358
    I calculate 285 uf to keep the ripple voltage down to 10% of 12 volts, but there is no good reason to mess with Mike's design unless you have some difficulty with the amount of ripple he has presented.
  14. alfacliff
    Dec 13, 2013
    2,449
    428
    what is r5 for?
  15. MikeML
    Oct 2, 2009
    5,451
    1,066
    It is his existing ~2A load.
  16. MikeML
    Oct 2, 2009
    5,451
    1,066
    Actually, the ripple helps keep the power dissipation in R1, R2 and D2 a bit lower.
  17. #12
    Nov 30, 2010
    16,705
    7,358
    I know.
  18. Hk606
    Oct 19, 2014
    19
    Just for clarity purposes the circuit is to operate a miniature air solenoid SMC model: vqz 100 series. Question: Is the R3 420 ohm resistor shown the resistance
    of the load or is this resistor added across the solenoid terminals. By the way. Thanks for the efforts on this!
  19. #12
    Nov 30, 2010
    16,705
    7,358
    Mikes R3 is pretending to be your load. It's only there for the simulation program.
  20. Hk606
    Oct 19, 2014
    19
    gotcha! Thanks.
