half bridge vs push pull
Discussion in 'General Electronics Chat' started by lokeycmos, Aug 4, 2012.
  1. lokeycmos
    Thread Starter Active Member
    Apr 3, 2009
    432
    7
    what is the difference between a half bridge and a push/pull configuration?
  2. MrChips
    Oct 2, 2009
    12,636
    3,454
    Can you please elaborate and give us more information and examples?
  3. lokeycmos
    Apr 3, 2009
    432
    7
    there are a lot of flyback transformer driver schematics. many of them have 2 transistors that switch a primary winding. ive heard them referred to as half bridge and some reffered to as push pull. i believe the two attachments are an example of each.
  4. MrChips
    Oct 2, 2009
    12,636
    3,454
    Hah! Now we know what you are referring to.
    A push-pull output driver gives you twice the bang for your buck.
  5. praondevou
    Jul 9, 2011
    2,936
    489
    A halfbridge usually has two switches and two capacitors to maintain a middle voltage between the positive and negative of the DC- bus. So what you posted is a halfbridge. The transformer works with one primary winding.
    A push-pull usually has two windings on the primary, so polarity is switched by energizing the two windings alternately.
    Read here: http://www.st.com/internet/com/TECH...AL_LITERATURE/APPLICATION_NOTE/CD00003910.pdf
    Figure 11, figure 12
  6. lokeycmos
    Apr 3, 2009
    432
    7
    thank you! that explains it.
