half bridge using IRF 2110 IC
Discussion in 'The Projects Forum' started by yeoh, Mar 12, 2012.
  1. yeoh
    May 17, 2010
    I need to build an half bridge using IRF 2110 IC. DO we need to connect the Vss which is pin 13 ?
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    Greetings! And welcome to AAC!
    Your post, originally posted here (http://forum.allaboutcircuits.com/showthread.php?p=465273#post465273), has been moved into its own thread, where it will draw more responses.
    Please refrain from "hijacking" existing threads with tangent or off-topic questions. You can create new threads for new questions using the "New Thread" button on the upper left of the page.
  3. shortbus
    Sep 30, 2009
    4,098
    1,697
    I'd say yes if you want it to work. Vss is the "logic" ground. This must be wired to your control signal ground point.
