Hair Iron Heater
Discussion in 'General Electronics Chat' started by R!f@@, Jan 20, 2012.
  1. R!f@@
    Thread Starter AAC Fanatic!
    Apr 2, 2009
    8,793
    771
    I like to reverse Engineer this
    So who's gonna help me ?:cool:
    I think I need to know the part no.'s first, Eh!.
    them transistors and diodes..so I can draw the schema..NO ?
    I got high res Pics..uploading them now..it will take some time.
    High res links are now available.
    1 2 3
  2. PaulEE
    Member
    Dec 23, 2011
    423
    32
    Heh heh heh...
  3. R!f@@
    Apr 2, 2009
    8,793
    771
    Keep giggling..
    Once I draw a schema out of it and showed it to ya, you would want to build something similar.
    It's how the heat is controlled I am interested in.
    U see, this thing takes 220VAC and regulates the heat of the plates without feed back and it is done through a SCR.
    This is what interests me.
    I blew the SCR, the wires shorted due to insulation wear. That's why I took it apart but always been interested in studying it..so here's my chance.
    First I need to replace the SCR and take some voltages..
    OK..since I lost most of my PDF files you guys gave me..
    I like to know what the SMD transistor no.s are.
    Can any one decipher the part no. ?
    Please..!
  4. R!f@@
    Apr 2, 2009
    8,793
    771
    OK ..I manage to read the no. s on the transistors..
    to really understand it u got to see this.
    Can any one tell me what they are actually, I mean the data sheets.
  5. plutoa34
    Jan 21, 2012
    This is really nice forum with awesome topics.
    Thanks for sharing.
  6. Sparky49
    Jul 16, 2011
    835
    417
    I'd like to try and help, but I cannot see the red letters on the black! Could you do it with white bold letters please?:)
  7. Lundwall_Paul
    Oct 18, 2011
    222
    19
    I learned something new today. I thought hair irons just had a cheap
    bimetallic thermostat in them.
  8. R!f@@
    Apr 2, 2009
    8,793
    771
    How about now
  9. thatoneguy
    Feb 19, 2009
    6,357
    718
    Which pins are the input voltage, which are the output to the heater element?
    The white/yellow device, soldered to both ends that sticks out, is that a thermal fuse or a thermistor?
  10. R!f@@
    Apr 2, 2009
    8,793
    771
    The unexpected happened.
    The comparator chip blew when I gave power after putting a new SCR.
    Interesting..:D
    BAAAANG !
    The picture has solder jumpers. Don't get hasty.. Pictures were taken during the de-soldering !
  11. R!f@@
    Apr 2, 2009
    8,793
    771
    Pads near the switch is the Input and the fuse is a 2A one
    and for ur info...it blew right to my face..that was something worth seeing..
  12. thatoneguy
    Feb 19, 2009
    6,357
    718
    Did the old SCR test bad?
    What is the comparator comparing, if you've figured out the operation of it yet...
  13. R!f@@
    Apr 2, 2009
    8,793
    771
    Operation ?
    If I tell you that the old SCR has Split. Would you believe that it is bad.
    And I do mean literally...
    To figure out anything I need to know the transistor part no.'s ...don't you think?
  14. spinnaker
    Oct 29, 2009
    5,114
    1,195
    A little super glue should fix you right up. :)
  15. thatoneguy
    Feb 19, 2009
    6,357
    718
    I figured you'd have a schematic done by now. :D
  16. R!f@@
    Apr 2, 2009
    8,793
    771
    Heck no. not yet..
    Too busy with the riot that is going on in here
