Hack or mod anything recently?
Discussion in 'Off-Topic' started by magnet18, Jun 16, 2011.
  1. magnet18
    Thread Starter Senior Member
    Dec 22, 2010
    1,232
    125
    If you've ever hacked something to make it better/fix it or modified an existing component, or just done a really good job wiring something, but it didn't deserve it's own thread, post it here!
    Personally, I just turned a 10 pole rotary switch into a 12 pole rotary switch and saved myself $2, all I had to do was a little bending of stops and cutting some metal to fit in the open slots.
    Take that greedy manufacturers!!
  2. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Well, I don't think it quite counts as a hack or a mod, but I'm working on a secret knock detector that senses a knock and unlocks a door if it's right. The original idea came from http://grathio.com/2009/11/secret_knock_detecting_door_lock/
    The original uses an Arduino, but all I have is a PIC18F1330. Since the site gives the program for the Arduino, I though't I'd translate it to work with C18 and my 1330.
    This project is helping me to learn about all sorts of things, including designing a PCB (which I had never done before):
    So yeah, I'm pretty excited about it :D
    Der Strom
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
    Don't spill the ferric chloride in your tub or sink if you plan to do it at home. It will stain any old porcelain surfaces, let alone your clothes.
  4. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Thanks, Georacer. I plan to have it professionally done, but thanks for the concern :D
    DS
  5. loosewire
    Apr 25, 2008
    1,584
    435
    You have knock detectors In auto to pick up noise in your engine.
    That If you have a auto with electronics.Have you compared the curcuits.
  6. #12
    Nov 30, 2010
    16,705
    7,355
    I recently found that Black&Decker 18 volt tool batteries have zero protection for the wall-wart transformer in their charger. The first time you plug in a really dead battery, the transformer melts. In addition, the wall-wart is rated at 2.1 amps and the steering diodes are 1n4007...1 amp. I added an LM338 TO-3 regulator to keep the current down to .9 amps, no matter how sick the battery is, and a LM317 voltage regulator set to the right voltage. It was 24.0 volts which ends up as 22.1 volts after the steering diodes and indicator LED. Now the charger charges batteries to the correct voltage and it is impossible to melt the charger or transformer.
    Before that, I bought a 2011 electric start lawn mower with 4 cables controlling self-propel speed, engine spark, starter interlock, and an engine brake. Then I put the motor on a 1995 chassis with cast aluminum transmission instead of the self-destruct plastic transmission and eliminated all but one cable. Then I got into the 100ma, no voltage limit, battery charger and added a 78L12 set for 14.2 volts as both a current limiter and a float charger with proper voltage limit.
    In between those two, I took my Water Boss water softener apart and flushed out the potassium permanganate that was turning harmless, water soluble, iron oxide into an insoluble form of iron oxide powder that gummed up the resin beads and plugged up the flow by 80%. I rinsed the iron oxide powder out of the resin beads, reassembled it, and no longer have a clogging problem or the usual 10 gallons of turbid water that it produced every time it regenerated...all for zero $.
    What amazes me is that all of these projects were done from Feb to May of this year. I hadn't thought of how many improvements I had found time for.
    ps, take that you greedy manufacturers!
  7. magnet18
    Dec 22, 2010
    1,232
    125
    I modified my lawnmower a while back.
    Had this annoying button you had to hold down when you went in reverse, I got fed up with it and just cut the wires and shorted it.
    Problem solved. :D
    I also modified my mustang. It was making a warning dinging chime all the time and I couldn't figure out why so I just ripped the warning module out.
    It's nice and quiet now ;)
  8. Georacer
    Nov 25, 2009
    5,151
    1,266
    I see: you 're a follower of the "Hand hurts? Cut hand" school.
    (sorry for the direct translation proverb)
  9. #12
    Nov 30, 2010
    16,705
    7,355
    I was afraid that if I unplugged the dinger board the turn signals or something might stop working so I just jammed electricians putty in the dinger.
  10. magnet18
    Dec 22, 2010
    1,232
    125
    Nah, the electronics still all work, I can just drive around with the hood up doors open and seatbelt off and it won't make a sound :D
    @georacer, would that translate to "hand hurts? Cut it off." ?
  11. Georacer
    Nov 25, 2009
    5,151
    1,266
    Nah, I translated on purpose on bad English, since the original phrase is in bad Greek too, to emphasize on the uneducated therapist.
  12. mbohuntr
    Apr 6, 2009
    413
    32
    A friend asked me to look at a Craftsman 18v battery charger unit that stopped working. I figured "This ought to be within my capabilities..."
    When I took it apart, It was only the fuse....:(
    At least the owner is happy now...
  13. #12
    Nov 30, 2010
    16,705
    7,355
    Ahh...good to know. Craftsperson much better tools than Blackendecker. Craftsperson tool has fuse!
    (Is that 70's thing over where saying, "Craftsman" is sexist?)
  14. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
  15. #12
    Nov 30, 2010
    16,705
    7,355
    So RRITESH, how did you accomplish this modification? Which parts did you change? How did you improve it?
    RRITESH KAKKAR likes this.
  16. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    I can't improve it, i have just hang it to watch FTA channel.
    i have mention all info. in my site...
  17. #12
    Nov 30, 2010
    16,705
    7,355
    I would like to announce the grand re-opening of this thread for people who have actually hacked or modded something.
    Thank you,
    #12
  18. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    OK, what you have hacked??
  19. #12
    Nov 30, 2010
    16,705
    7,355
    Read post number 6.
    If you don't read the posts or the title of the thread you can't know what the conversation is about.
