I have created an H-bridge PC with 4x floating gate drivers and 4x IGBTs (see attached schematic showing half of h-bridge).
It works very nicely but I would like to replace the IGBTs with n-channel MOSFETs. However, all the H-bridge designs I've seen use n-channels on the low side and p-channels on the high side.
Since my design uses independant galvanically isolated DC-DC converters which effectively provide each of the 4x gate drivers with their own floating supply, is it possible that I can just do a simple straight swap between of the IGBTs with N-channel mosfets?
